13 years agoProblems working thru "Using Triple-Speed Ethernet on DE2-115 Boards"
I'm trying to get this running.. it is an 'altera corporation - university program' pdf of a triple speed ethernet design. Sort of a bare-bones way to get ethernet working at 10/100/1000 with a NIOS...
12 years ago --- Quote Start --- Hi david1024, Thank you for detailing your experience with this code. I have run into almost all of the above problems mentioned as well. However I find that the issue I quoted still happens sporadically, and so it is difficult to trace it back to a root problem. Did you find any reasons or fixes related to board not transmitting when it was supposed to? Thank you, Leigh --- Quote End --- I would suggest going through the tutorial with the version of Quartus and EDK it was written for. That'll make sure your hardware is working correctly. As to intermittent problems... I really can't help much other than suggest using eclipse/signaltap to monitor/track down the problem.
