13 years agoProblems working thru "Using Triple-Speed Ethernet on DE2-115 Boards"
I'm trying to get this running.. it is an 'altera corporation - university program' pdf of a triple speed ethernet design. Sort of a bare-bones way to get ethernet working at 10/100/1000 with a NIOS...
12 years ago --- Quote Start --- The system and code works, problem was ethernet cable between eth0 and eth1 --- Quote End --- Hello Everyone, I have the same problem with DE2-115 Board. I created tse_tutorial.v by following triple-speed ethernet on DE2-115 boards tutorial file. The leds at etho and eth1 are also showing after running the program (action->continue) at the monitor. But, nothing is displaying in terminal window. Any suggestions?
