15 years ago --- Quote Start --- I have tried enabling SignalTap and probing the output pins during the write operation, SignalTap reports correct operation but the outputs, as measured on a real logic analyser, are wrong. E.g. for CHANNEL=1, eeprom_en='0', path=0 I should get 0,0,0,0,B,A, 3,2, I actually get 0,0,0,0,9,8,3,2 --- Quote End --- When even SignalTap reports correct behavior, it looks like a problem that is related to your hardware somehow, e.g. an incorrect pin-out, bad soldering-joint or a short-circuit between two pins, etc. Have you measured also with a scope to see if you get clean logic-levels on the outputs? Thomas
