Altera_ForumHonored Contributor15 years agoProblems with programming a CFI Flash Hello, I have a problem to program a CFI Flash. Following is the Information output from the Nios II Flash Programmer: Executing command: $SOPC_KIT_NIOS2/bin/bin2flash --input="D:/FileSyst...Show Moremultiple-attachments.zip194 KB
Altera_ForumHonored Contributor15 years agoYou are using 16-bit mode? I tried 8-bit mode, it worked, but 16-bit, not worked.
Recent Discussionsstarting to learn FPGAsqsys-generate outputs Info as ErrorTiming analysis - long combinational pathQuartus Prime Lite 25.1 License Error - "Unable to checkout a license" (SALT_LICENSE_SERVER)Regarding the issue of UFM not starting
