8 years agoProblems with graphics on Quartus 17.1 lite
I recently installed Quartus on my laptop to be able to do school labs from home. The software works great and runs very quick on my laptop but I am having problems with the symbols and schematics appearing squished and very hard to read. I am running it on a 2017 MacBook Pro, in parallels with Windows 10. is there a way I need to configure the set up to fix the problem? I've included a screen cap of how the files are showing up on my computer.10 Replies
if you zoom in, does the issue remain? I've seen this when I look at a schematic on a zoomed out view.
You can modify font & colors of the schematic from “Tools” menu select “options” Find the attachment for reference & try it by yourself. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) - Altera_Forum
Screen Shot Indicates that Font settings are changed so first Reset Font setting, Refer Attachment. Here is “Tools” -> “Options ...” -> “Block/Symbol Editor” Under “Category”. Note here clearly maintained that “Font Changes will not affect existing objects. It will only take effect when adding new objects” Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) - Altera_Forum
First Open The Project ->open schematic file (.bdf) Then Go to “Tools” -> “Options ...” -> “Block/Symbol Editor” Under “Category”. Otherwise you will not find this option. Check bellow screen shots. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) https://www.alteraforum.com/forum/attachment.php?attachmentid=15021 https://www.alteraforum.com/forum/attachment.php?attachmentid=15022 https://www.alteraforum.com/forum/attachment.php?attachmentid=15018 https://www.alteraforum.com/forum/attachment.php?attachmentid=15019 - Altera_Forum
--- Quote Start --- Hi, First Open The Project ->open schematic file (.bdf) Then Go to “Tools” -> “Options ...” -> “Block/Symbol Editor” Under “Category”. --- Quote End --- Does that also work with generated schematics (rtl viewer etc)? - Altera_Forum
We don`t have “Options..” menu under “Tools” menu so It doesn’t work for rtl viewer. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) - Altera_Forum
Was anyone able to fix this issue? I'm having similar issues with Quartus II 13.1 64 bit
I have the same problem in Quartus 17.1.1. My OS is Windows 7, the monitor is 15.6 ", the resolution is 1920 x 1080. The OS settings set the font's scaling to 150% .The above tips do not give any result.
The settings in "Tools" -> "Options ..." -> "Block / Symbol Editor" do not change anything. When I set the font scaling to 100% in the OS, everything is displayed normally. But with this scaling, working on a 15.6 "monitor is not convenient, that is, Quartus does not work correctly with scaling in the OS. How to solve this problem?
