15 years agoHmm... Still having a few problems with this... as I said I am very new to VHDL.
I can't avoid using the bidirectional signals/pins, as this is for the 245 Communication Interface between the Cyclone II and the FTDI FT2232H USB Bridge chip on the board. I am only trying to establish simple communications over USB and for now just echo back recieved characters. This means to test my design I want my test bench to be able to input data into the AD[0..7] pins, then processed this data (in my design I am just trying to invert each bit of the byte for now) and then when its clear to transmit change AD[0..7] to outputs to output the data back to the FTDI chip (which puts the data into a transmit FIFO buffer to be send over USB.) The output enable shown below "N_OE" is the output enable for the FTDI chip and so is used when reading from the FTDI chip, i.e. using AD[0..7] as inputs. At the moment my values of AD[0..7] are now just appearing as either Z or X but not with any values on... The ammended code for my test bench is included... Cheers
-- This file contains a Vhdl test bench template that is freely editable to
-- suit user's needs .Comments are provided in each section to help the user
-- fill out necessary details.
-- Generated on "10/13/2010 16:36:17"
-- Vhdl Test Bench template for design : Morph_USB_LOOPBACK
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY Morph_USB_LOOPBACK_vhd_tst IS
END Morph_USB_LOOPBACK_vhd_tst;
ARCHITECTURE Morph_USB_LOOPBACK_arch OF Morph_USB_LOOPBACK_vhd_tst IS
-- constants
-- signals
SIGNAL testdata : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL AC : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL AD : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL clkout : STD_LOGIC;
SIGNAL N_OE : STD_LOGIC;
SIGNAL rst : STD_LOGIC;
SIGNAL siwua : STD_LOGIC;
COMPONENT Morph_USB_LOOPBACK
PORT (
AC : INOUT STD_LOGIC_VECTOR(3 DOWNTO 0);
AD : INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
clkout : IN STD_LOGIC;
N_OE : OUT STD_LOGIC;
rst : IN STD_LOGIC;
siwua : OUT STD_LOGIC
END COMPONENT;
BEGIN
i1 : Morph_USB_LOOPBACK
PORT MAP (
-- list connections between master ports and signals
AC => AC,
AD => AD,
clkout => clkout,
N_OE => N_OE,
rst => rst,
siwua => siwua
init : PROCESS
-- variable declarations
BEGIN
if (N_OE = '0') then
AD <= testdata;
else
AD <= "ZZZZZZZZ";
end if;
testdata <= "00000000", "10101010" after 166.6 NS, "11110000" after 499.8 NS;
AC(0) <= '1', '0' after 183.2 NS,'1' after 266.2 NS, '0' after 582.8 NS, '1' after 665.8 NS;
AC(1) <= '0', '0' after 333.2 NS, '1' after 499.8 NS, '1' after 582.8 NS;
rst <= '0';
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
-- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
END Morph_USB_LOOPBACK_arch;
