15 years agoProblems with ALTASMI_PARALLEL megafunction
Hi, I'm trying to use ALTASMI_PARALLEL in a Cyclone design with an EPCS1. The problem is that all the code which drives this megafunction, and the megafunction itself, gets optimised away duri...
10 years agoThanks Rhydian,
The attribute preserve led me to another attribute that seemed to be more suitable, prune. But I could not get it to work, I ended up connecting one of the address lines to an unused pin. I still think it's strange that Quartus does not know that altasmi_parallel is connected to some pins internally and should not be optimized away. So if someone have a good answer in the future I would really appreciate if you could put a note in here to let us know. / Joakim
