15 years agoProblems with ALTASMI_PARALLEL megafunction
Hi, I'm trying to use ALTASMI_PARALLEL in a Cyclone design with an EPCS1. The problem is that all the code which drives this megafunction, and the megafunction itself, gets optimised away duri...
10 years agoI have a similar problem, but I don't read at all. I only use the component to write to the configuration memory.
I have tried to set rden=1 (which feels strange when you don't want to read), but the component is optimized away anyway. Is there any specific operation I need to perform to get it to stay in my design? I tried to forward some of the address lines to a debug pin or use signal tap, in this case the component stays and work, but I don't want this code in my final product. Thanks / Joakim
