10 years agoProblems with ADA Utility Program
Hey Guys,
I'm completly new with fpgas and so on so excuse me if I would write stupid things. Well I got an Altera DE2-115 Board with an Cyclone 4 FPGA and a Altera terasIC THDB-ADA_HSMC Board. I just wanted to try out the demo program "Waveform Generator". -First I tried the quartus 2 program and it worked fine. I just have some problems to find the right things but I think that would come with time. -After this, I wanted to try out the ADA Utility program. First I got some Errors about missing dlls(fyi: I use Windows 7, 32 bit). I copied the dll into the order and it worked. Now I wanted to start the ADA Utility but everytime I got the follwing error message: --'1.000' is not a floating point value-- This message pops up everytime. When I press ok, than it tries to connect but it doens't work. I got no error message but I got no output on my oscilloscope. So, do I anything wrong? Or has someone a tip for me? Thanks a lot! Mary1 Reply
ahaha ok I think I solved it :D I had to change my regional settings. Now it works :D
