8 years agoProblems trying to configure three FPGAS using the EPC16
The aim of this thread is to request help from you guys because I have a problem trying to make a .pof file which is driving me crazy. I am working on a card which has three FPGA (each one runn...
8 years agoHi,
--- Quote Start --- Using the "convert programming files" tool I produced a .pof file from the three .sof files (one for each FPGA) but for a reason which I cannot understand the FPGAs are not programed (done line does not go high) when I power cycle the card. --- Quote End --- For multi-device configuration chain, add the SOFs according to the order of the devices in the chain. Check the status of MSEL pin & other configuration signals. Check jumper settings on a card. Refer the following document for the “Conversion of SRAM Object File to Programmer Object File for Parallel Flash Devices” https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an478.pdf Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
