8 years agoProblems to program Cyclone V GT FPGA
Im new using Altera boards I have two questions. I check the Quartus_II_Introduction for verilog users. On the programming chapter it says that "DE0-CV, DE0-Nano and DE2-115 Boards" should have a...
8 years agoThank you FvM and Anand Raj Shankar
I was able to get the pin Assignment by searching a bit more on internet. As for the programming the FPGA I still have some problems, here is what I do: SW1, SW3, SW4 default configuration SW4: Also I tried Factory user = off SW5 I tried with default configuration SW5 I tried with MSEL1 0 and 1 To activate Active Serial MSEL 0 and MSEL 1 should be 0 , 0 according to 13. Configuring Cyclone FPGAs (Cyclone Handbook Volume 1 chapter 13) *Quartus Prime Lite Edition Software Load project Assigments->Device->Device and Pin Options Configuration scheme: Active serial 1x Configuration device Auto Compile File->Converting Programming File Programming file type: JTAG indirect configuration file *.jic Configuration device: EPCQ128A/EPCS128 Flash loader->Add device: Cyclone V / 5CGTFD9E5 SOF Data->Add file: File.sof Generate *Quartus Prime Programmer Lite Edition Software Autodetect 5CGTFD9E5 Select 5CGTFD9E5 click change file select file.jic Check Program/Configure checkbox Start Operation failed The error I got is Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly. Error (209012): Operation failed
