10 years agoProblems running sdram pin assignment tcl script on Linux
I'm generating a HPS setup for a Cyclone V device. When I run the auto generated script soc_system/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl it fails. In Quartus command-line the fa...
9 years agoI still have the same problem on Ubuntu 16.04 with Quartus 17.0.2 unfortunately.
What distro do you guys use for desktop use? Centos is mentioned above, which version? *edit* Perhaps one can experiment with running Quartus in Docker to have the proper library environment which it apparently relies on? I see that there actually exists a few containers with quartus.
