10 years agoProblems running sdram pin assignment tcl script on Linux
I'm generating a HPS setup for a Cyclone V device. When I run the auto generated script soc_system/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl it fails. In Quartus command-line the fa...
10 years agoHmm, I see now that the only supported distro for Linux is Red Hat Linux. I don't remember last time I saw someone use that. Its on 44th place of distrowatch.com lists.
Does this imply that other rpm-based distro, such as Fedora, will work better? I wonder if Fedoras system setup and libraries and such still resebles RedHat.
