10 years agoProblems running sdram pin assignment tcl script on Linux
I'm generating a HPS setup for a Cyclone V device. When I run the auto generated script soc_system/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl it fails. In Quartus command-line the fa...
10 years agoUbuntu is not a supported OS for Quartus. I've seen posts elsewhere in the forum that show how you can get it to work by installing additional libraries. Look around a bit. This may or my not have anything to do with why you are having this problem.
