16 years agoProblem wuth altsyncram
Hi, I included in a top level schematic design an altsyncram function. I configured the altsyncram with MegaWizard as a true dual port ram (both rd and wr on each port), 8 bit wide and 4096 deep...
16 years agoThis is what I understood.
But the clock is actually already connected: single clock for both ram ports. Any other suggestion? I changed mem depth, added separated clocks for each port, regenerated the component, but always the same error. I generated HDL from bdf schematic and all seems to be ok. You can see the clock connection is there. clk_50m comes from a pll and feeds other devices, too. Verilog:
dp_ram b2v_inst24(
.wren_a(ext_wren),
.rden_a(ext_rden),
.wren_b(dsp_wren),
.rden_b(dsp_rden),
.clock(clk_50m),
.aclr(resetn),
.address_a(ext_addr),
.address_b(dsp_addr),
.data_a(ext_data),
.data_b(dsp_data),
.q_a(ext_data),
.q_b(dsp_data)); VHDL:
b2v_inst24 : dp_ram
PORT MAP(wren_a => ext_wren,
rden_a => ext_rden,
wren_b => dsp_wren,
rden_b => dsp_rden,
clock => clk_50m,
aclr => resetn,
address_a => ext_addr(12 DOWNTO 0),
address_b => dsp_addr(12 DOWNTO 0),
data_a => ext_data(7 DOWNTO 0),
data_b => dsp_data,
q_a => ext_data(7 DOWNTO 0),
q_b => dsp_data);
