10 years ago
Problem working (using nichestack TCP/IP - nios 2 ) tutorial
Hello
I have been following the tutorial https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/tt/tt_nios2_tcpip.pdf
I used the Nios II Ethernet Standard Design Example of stratix IV https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-net-std-de.html
My quartus version 15.0 and the example was for version 12.0
I have only changed the tse_mac (Triple Speed Ethernet) from the Ethernet_system.qsys subfile to support the Stratix IV board
in the top level code of the example there are those components
.tse_mac_conduit_connection_mdc (enet_mdc),
.tse_mac_conduit_connection_mdio_in (mdio_in),
.tse_mac_conduit_connection_mdio_oen (mdio_oen),
.tse_mac_conduit_connection_mdio_out (mdio_out),
.tse_mac_conduit_connection_ref_clk (clkin_125),
.tse_mac_conduit_connection_rxp (enet_rx_p),
.tse_mac_conduit_connection_txp (enet_tx_p),
.flash_tcm_address_out (fsm_a),
.flash_tcm_data_out (fsm_d),
.flash_tcm_read_n_out (flash_oen),
.flash_tcm_write_n_out (flash_wen),
.flash_tcm_chipselect_n_out (flash_cen)
when I compile the example it says it did not find those components in the main (eth_std_main_system)
I will appreciate if someone guides me what do those components represent, I assume the tse part is because I changed that part in the Qsys file but I want to know what each one represent so I can put on the changed part
whats mdc, mdio, ... etc?
