12 years agoProblem with tri-state controller
Hi everyone!
I'm trying to use tri-state controller to connect nios2 system to w5300 chip (w5300 is considered as SRAM). Write command works very strange: two nWR pulses and two nCS are formed, so two write operations are executed. Address value stays the same during both write operations, but data changes to all zeros before second operation, so firstly correct value is written into SRAM, but then controller writes zero to the same address. If I change some timing options (setup time=0, write wait time=0, data hold time=0) only one pair of nCS/nWR pulses is formed, but these changed timing options don't correspond to required write diagram. Has anybody faced this issue?
