8 years agoProblem with tcl automation script
Hi. I want create a TCL script which will be write into log file after compilation current revision of a project, current timestamp, current active signaltap file name and current revision ID. I have try get current signal tap file name with command
set stp - valie]
This command work correctly if I run it TCL shell in Quartus II window, but I have error when run this command in script as POST_FLOW_SCRIPT_FILE: You must open a project before you can use this command. Thanks for help.2 Replies
You have to first open the project with project_open.
Thank. I use project_open command and dont have this error. But now when I use command get_current_revision for get active revision I get default revision name. Do you know why?
