15 years agoHi Antonio,
You use two clocks in one process (coe_iVHA_HS and coe_iVGA_CLK). Like you said that could work in simulation, but how would a hardware implementation look like? I would make a seperate process for the flag_hs signal, which look like: process(coe_iVGA_HS, coe_iRST_N, reset_hs_flag) begin if coe_iRST_N = '0' or reset_hs = '1' then flag_hs <= '0'; [/INDENT] elsif(coe_iVGA_HS = '1' AND coe_iVGA_HS'event) then flag_hs <= '1'; [/INDENT] end if; end process; define a signal reset_hs_flag and change line 112 to reset_hs_flag <= '0'; line 125 to reset_hs_flag <= '1'; Remove lines 116 and 117. I dont know if coe_iVGA_HS and coe_iVGA_CLK are asynchronous. If they are, take measures for clock domain crossing. Succes, Ton
