Problem with signaltap implementation on a stratix 10 development kit
Correct SignalTap file has to be selected in Project settings under SignalTap II.
Check if the .sof file loaded to the device is actually the new generated one.
Need to add SignalTap .stp file before we compile and built the project.
Also delete the db folder check.
If you still facing problem,
it may be due to logical issue, To confirm that we can create a simple project with stp and test it.
Or
May be due to Tool issue, use latest version of quartus and check.
Anand
I have ensured that the signaltap file is included in the project, and that I'm using the latest .sof file.
I created a simple project with just a clock and a signal which interacts with the clock, and I still got the same problem. The test project is attached.
