15 years agoHi feizhang,
a negative value for clock skew? For what I know a negative value on clock skew tends to exacerbate setup timing problems. But as you said that your design only runs at 6 MHz this should not be the problem. Let's try to go to the basics: 1) Is your design fully synchronous (every flip flop clocked from the same clk signal)? 2) Did you remove all the latches? 3) Did you put a flip flop on every input signal before any logic? If the answer is yes to all the question then the problem is not easy to solve...
