rx and tx are just conventions, you can use them in any direction you want. But you need to keep the pairs together if you use them as LVDS (i.e. HSMC_TX_p4 and HSMC_TX_n4 together, but not HSMC_TX_p4 with HSMC_RX_p11).
For the pins that you use as general I/O if you don't use LVDS you can use any pin as you want, as input or output.
If you have a lot of data to move from/to the PC, it may be easier to use the Ethernet port. The embedded USB Blaster only allow communication through JTAG, and you would need to use a virtual JTAG component or the JTAG uart.
