8 years ago
Problem with compilation of vector_add example
Hello everyone.
When running the command:
aoc device/vector_add.cl -o bin/vector_add.aocx --board de5a_net_e1 --report
I get the following message:
aoc: Selected target board de5a_net_e1
/home/vista_fpga/intelFPGA_pro/16.1/hld/board/de5a_net_e1/tests/vector_add/device/vector_add.cl:23:48: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
__kernel void vector_add(__global const float *x,
/home/vista_fpga/intelFPGA_pro/16.1/hld/board/de5a_net_e1/tests/vector_add/device/vector_add.cl:24:48: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
__global const float *y,
2 warnings generated.
; Estimated Resource Usage Summary ;
; Resource + Usage ;
; Logic utilization ; 19% ;
; ALUTs ; 10% ;
; Dedicated logic registers ; 10% ;
; Memory blocks ; 11% ;
; DSP blocks ; 5% ;
Error: Peak virtual memory: 871 megabytes
Error: Processing ended: Fri Nov 10 15:27:49 2017
Error: Elapsed time: 00:00:19
Error: Total CPU time (on all processors): 00:01:01
Error: ip-generate FAILED.
Refer to vector_add/vector_add.log for details.
In the vector_add.log file, the last lines are:
Info: Generating kernel_system.qsys:
Info: qsys-generate -syn --family="Arria 10" --part=10AX115N2F45E1SG kernel_system.qsys
while executing
"qexec "qsys-archive --quartus-project=$project_name --rev=opencl_bsp_ip kernel_system.qsys""
(file "scripts/pre_flow_pr.tcl" line 134)
Error (23031): Evaluation of Tcl script scripts/pre_flow_pr.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 1 error, 0 warnings
My OS is Centos 7.
Lancer
    Hi HRZ,
    Shifting to v16.0 did solve the problem. Thank you!
    Ill contact Terasic and report them the bug.
    Need to take note that BSP version are specific to SDK version as well.
    CloseCL
