8 years agoProblem with ByteBlaster under Windows10/64: "Error (213043): More than one.."
Hi all We have following problem: We are using the "ByteBlaster" for programing our Altera devices. For now this worked perfectely (with WinXP/32 and Win7/64) but now we are trying to switc...
Carlhermann
7 years agoHi,
we have some similar, but otherwise different Problem. We have two USB Blasters installed in the Setup, one of them connected to the "to be programmed" electronics, the other one unconnected at the programming I/F, just being connected by USB. As already mentioned, you cannot be sure which one is recognized as [USB-0] and which as [USB-1]. Therefore, the user needs to try one of them, either being lucky or - if that fails - try the other cable. Can this "try and error" be automated? The idea is to start one programm and than the connected one is either detected or if the try with one fails, the second is tested automatically…
Thanks a lot, Carlhermann
