12 years ago --- Quote Start --- Thank you for your answer. So, if I good understand - without external clock signal I can not deal with this task? --- Quote End --- FPGA design is based on clk. However in some cases one can do without it (as did old digital engineers) provided you are really skilled in asynchronous design, I am not and so are most of fpga designers. Is't that difficult to get clock signal? designing asynchronously will be more difficult than getting a clk on board. At the end it might be just possible if your design is simple and accepts delay variations.
