12 years agoI did as you wrote and created register - code is below
library ieee ;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
ENTITY CLK_REG IS
port (clk, reset : IN STD_LOGIC;
q1, q2 : OUT STD_LOGIC );
END CLK_REG;
ARCHITECTURE arch9 OF CLK_REG IS
BEGIN
-- Register with active-high clock
PROCESS (clk, reset)
BEGIN
IF reset = '0' THEN
q1 <= '0';
ELSIF clk'EVENT AND clk = '1' THEN
q1 <= '1';
END IF;
END PROCESS;
-- Register with active-low clock
BEGIN
IF reset = '1' THEN
q2 <= '0';
ELSIF clk'EVENT AND clk = '0' THEN
q2 <= '1';
END IF;
END PROCESS;
END arch9;
I enabled this by clock created from hall signals and expected to get on my outputs: q1 = 1, and q2 = 0 when clock = 1; q1 = 0, and q2 = 1 when clock = 0; And this part works. Then I changed a synchronous part of my state machine as below:
process (q1, q2)
begin
if (q1 = '0' and q2 = '0') then
y_act <= A;
elsif (q2 = '1' and q1 = '0' ) then
y_act <= y_next;
elsif (q1 = '1' and q2 = '0') then
y_act <= y_next;
end if;
end process ;
Unfortunatelly this part doesn't work at all. It changes all the time states only between A and B. Can you tell what mistake I do in this case?
