15 years agoHello.
I have finally resolved both issues. 1) Altera says that the Altera Software Installer 10.0.220.1 has problems with some proxies: "Note that the Altera Installer supports only basic authentication-based proxies at this time. NTLM-based proxy servers (check with your system administrator) are not supported and may cause the Altera Installer to hang. If your proxy requires NTLM authentication, you can download and install the ACDS version 10.0 using the individual software file instead." 2) I have installed the 9.1sp2 version of ACDS, and I have found the examples. But I have not found the examples in 10.0 sp1 version yet.
