11 years agoProblem with Alignment
Hey ,
I got the warning message about "Non Using DMA for transfer ... lack of alignment". The data structure I used looks like as follows : """"" typedef struct{ double test1 , test2; int test3; }Test; typedef struct{ double temp1; double temp2; double temp3; double temp4; Test temp5[256]; Test temp6; }temp; """"" And I add the " __attribute__((aligned(64))) " in host and kernel like as shown : """"" typedef struct{ double test1 , test2; int test3; }Test; __attribute__((aligned(64))) typedef struct{ double temp1; double temp2; double temp3; double temp4; Test temp5[256]; Test temp6; }temp; """"" Then I executed the program and the warning message still happened and segmentation fault. It seems that the data can't not transfer between host and FPGA , and the program will be stopped. Could anyone help me , please : ((( Thanks1 Reply
You probably need to manually align the data structure on the host side for example, using posix_memalign.
... temp tmp_struct; posix_memalign((void**)&tmp_struct, 64, sizeof(temp)); ...
