15 years agoif you want to implement in memory then you need to think carefully of a plan. The basic idea might be to use above counter as address then each location is encoded for some specific action. filling up the memory with a mif file then becomes a major work but avoids the use of the otherwise huge logic. In effect you are designing a processor.
