15 years agoHi,
never tried to use such a huge FSM but... Quartus is problably trying to use one hot encoding. You can try and add the following, to have Quartus use a sequential encoding, which attribute syn_encoding : string; attribute syn_encoding of state_reg : type is "sequential"; That said.. 70k states? *wow* It's hard to see what your application is but 70k states is .. a lot. Probalbly, you should consider other aproaches. Maybe a 8 bit embedded processor core would help you.
