14 years agoproblem to change from Quartus 9.0 to Quartus 11.1
hello together,
i want to change my development tool from quartus 9.0 to 11.1_173. in the moment i can build my core in SOPC and it is possible to import this core in NIOS IDE 11.1. But if i want to compile the nios application with the bsp in NIOS IDE i get messages from console "CreateProcess(...) failed.", "make (e=87): wrong parameter." and "make: *** [*.elf] Error 87" I was change the Settings for the builder settings generally to start the build process so is it necessary to set even more points? Is there any idea or experience with a changing of the development tools quartus to a higher versions
