--- Quote Start ---
why not post the origional code?
--- Quote End ---
Sure, by the way, all my FSM projects have the same issue, so I'll post a simple example because
that one is very long.
module FSM(clock, reset, w, z);
input clock, reset, w;
output z;
reg y_Q, Y_D; // y_Q represents the current state, Y_D represents the next state.
parameter A = 4'b0000, B = 4'b0001, C = 4'b0010, D = 4'b0011, E = 4'b0100,
F = 4'b0101, G = 4'b0110, H = 4'b0111, I = 4'b1000;
always@(w, y_Q)
begin: state_table
case(y_Q)
A: if(!w) Y_D = B;
else Y_D = F;
B: if(!w) Y_D = C;
else Y_D = F;
C: if(!w) Y_D = D;
else Y_D = F;
D: if(!w) Y_D = E;
else Y_D = F;
E: if(!w) Y_D = E;
else Y_D = F;
F: if(!w) Y_D = B;
else Y_D = G;
G: if(!w) Y_D = B;
else Y_D = H;
H: if(!w) Y_D = B;
else Y_D = I;
I: if(!w) Y_D = B;
else Y_D = I;
default: Y_D = 4'bxxxx;
endcase
end // state_table
always @(posedge clock)
begin: state_FFs
if(~reset) y_Q <= A;
else y_Q <= Y_D;
end // state_FFs
// Outputs
assign z = (y_Q == E) | (y_Q == I);
endmodule
Thank you so much sir, your help is so appreciated.
