16 years agoHi, thanks for the quick response.
I dont think anything is running because the main clock divider does not appear to be working. It uses an ALTPLL component. I dont see any of the divided clocks being output on pins. I'm not sure I understand what the remote vs local update is exactly. I'll have to check that. One thing I'm a bit unsure about is the use of configuration data compression. There seems to be two different places to set it and the discription of the use is a bit confusing. I know I have to use it because with it turned off the data will not fit in the configuration flash device. I am actually using the old project file so I would assume the settings are the same as the original project. If they werent not sure how I would know. Is there any way to look at the .pof file I downloaded from the working board and tell what any settings were based on that?
