16 years ago --- Quote Start --- Ok. This morning that works. In fact I have to close the project and reopen it so that it works (I should test this simple thing yesterday). But that stays strange. Another question, is it possible to tell Quartus to search recursively in the folder project, to avoid to add each folder ? --- Quote End --- Hi LETS, I had a brief talk with the Altera Guy's : If you want to use specific user assigned user libraries then you are required to specify each one manually as these will :mad: ...this ensures that projects are kept clean and do not pull in and undesired files. Kind regards GPK
