Problem launching SBT Eclipse 9.1sp2 on Linux centOS 5.5
Hello.
I am trying to follow the tutorial about how install Quartus II on centOS from Nios Wiki:
http://www.nioswiki.com/OperatingSys...uartusforLinux
I am using 9.1 sp2 software instead of 9.1 sp1 wich is used in the tutorial.
For that reason, I had to modify the "n2sdk" file. I changed the lines wich had "/opt/altera9.1sp1/" to "opt/altera9.1sp2/".
Quartus II runs fine except for the next message:
"warning: Can't contact license server "1800@localhost" -- this server will be ignored "
I am using Quartus II web edition. For that reason, I don't care about the license.
SOPC Builder runs fine, but when I try to run SBT Eclipse, I have the problem. It runs fine until the wokspace prompt. In that prompt, I have tried many directories, but after that, when the program is loading again, it stops, and appears the message that is shown below:
"An error has ocurred. See the log file
/home/takumikite/workspace/.metadata/.log"
When I open that ".log" file, appears the next text:
See attached for log
I had to cut the text because it has too many characters, but the part of the text that I cut is like the first part of the text:
"!ENTRY org.eclipse.ui.workbench 4 0 2010-11-12 11:31:46.909
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.WorkbenchPartReference$1.w idgetDisposed(WorkbenchPartReference.java:171)
at org.eclipse.swt.widgets.TypedListener.handleEvent( TypedListener.java:117)
This part is repeated many times, until reach the last part:
"!ENTRY org.eclipse.osgi 4 0 2010-11-12 11:46:50.564
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: XPCOM error -2147467262
Could you help me?.
Thank you.
