9 years agoProblem in using the same module in project for many times
Hi everyone, I am trying to use one module for several times in one project cause I want to control several ADCs using one main project. And my way to do it is like this:
ADC ADC1(.RS...
8 years ago --- Quote Start --- Hi sstrell, I fixed this problem. It is not because of timing requirement, it is because I use the same clock input(CLK, shown in my code before) for this two ADCs. Actually these two ADCs can not work at the exactly same time. so they can not share the same clock. I will set DOUT as a basic clock to decrease that warning! DOUT is a combined pin, if there is no new data from ADC, DOUT acts as ready signal. Once there are new datas from ADC, DOUT trigger my board to send in SCLK and read data out. Thank you very much for your advise. Yours Yonghang Tian --- Quote End --- Hi, yonghang, Congratulations on you make it! And I meet the same problems, I configured the same three ADCs module in my project, see in the following, sample sample_adc1( .clk(clk), .rst_n(rst_n), .miso(miso1), .mosi(mosi1), .csn(csn1), .sclk(sclk1), .data(data1) ); sample sample_adc2( .clk(clk), .rst_n(rst_n), .miso(miso2), .mosi(mosi2), .csn(csn2), .sclk(sclk2), .data(data2) ); sample sample_adc3( .clk(clk), .rst_n(rst_n), .miso(miso3), .mosi(mosi3), .csn(csn3), .sclk(sclk3), .data(data3) ); //clk--input external clock 25MHZ, rst_n--reset miso--AD7888 output sample data to FPGA mosi--FPGA output configure data to AD7888 csn--chip select sclk--FPGA output serial clk to AD7888 my problem is : when I only use one ADC in my project , the result is correct , but when I use two or three ADCs module , There is interference between the data (I use in system sources and probes editor to watch the result), thus i can't get all correct data and get warning messages: Warning (332060): Node: sample:sample_adc3|csn was determined to be a clock but was found without an associated clock assignment. ...........................................(much) I changed the clk , using three output clock form PLL module, but i seems no difference, I need your help! THANKS!
