17 years ago
Problem in building a LCD panel controller in SOPC
I use the quartus II 9.0,
I want to creat a TFT controller , but got some problem:
TFT panel : 800*480 、24bit parallel RGB(three colors in parallel)data out;
question 1:
in video sync generator
Data stream bit width:24
Beats per pixel:1
in pixel converter (bgr0-> bgr)
Source symbols per beat:3
error:
the source has 8 bits per symbol while the sink has 24;
the source has 3 symbols per beat while the sink has 1;
I feel puzzled with this,
In 24bit parallel RGB, what parameters should set in above two blocks?
or Video sync generator can’t generate 24bit parallel RGB signals?
question 2:
I use a 8bit data width sdram,but set the the data width of SGDMS to 64bit? is that proper?
question 3:
I download nios_lcd_3c120 design example from Altera,but it didn’t use frame buffer block of video and image processing, does frame buffer block is a new block of quartus II 9.0? is it necessary to use this block to build buffer in external memory ? (nios_lcd_3c120 doesn’tuse)
And how to use it?
