12 years agoProblem compiling fft example
I'm trying to compile the fft example. I'm using the command-line suggested in the readme.txt file:
aoc --board pcie385n_d5 --sw-dimm-partition --const-cache-bytes 16384 fft.cl but the compile gives an error: Info (12128): Elaborating entity "altera_merlin_slave_translator" for hierarchy "system:system_inst|altera_merlin_slave_translator:fft_system_avs_fft_cra_translator" Info (12128): Elaborating entity "system_irq_mapper" for hierarchy "system:system_inst|system_irq_mapper:irq_mapper" Error (293007): Current module quartus_map ended unexpectedly Error: Flow compile (for project /work/altera/designs/fft/fft_pcie385n_d5/fft/top) was not successful Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
