16 years agoproblem cant generate post-fit netlists for design partitions
I have a large project that I split into design partitions a while ago. As I modifiy each section I set the design partitions to source file and back to post-fit when successgfully copiled and working. This is mainly to speed up compile time but there are some speed critical parts of the design I wish to preserve the routing on. This worked fine until recently when I discover I am now getting the message: 'Warning: Interface for the following design partitions was changed by necessary netlist modifications during the Fitter - disabling usage of Post-Fit Netlists generated from this compile' under this warning the detail is: ' Warning: Partition "hard_block:hard_block_inst"'s interface was changed' I don't know what hard_block is or how to find out. It is not something I've designed. The result therefore is that the post-fit netlists are not available for my partitions to use! The design does contain a nios and this is one of the partitions. There are about five other partitions all on a top level sheet. I have tried deleting the database and re-compiling from scratch but this has made no difference. Please can anyone point me in the right direction as to how to find my problem. Thanks Dave
