13 years agoProblem! Binary Divisor: Error (10028): Can't resolve multiple constant drivers
Hi! I'm trying to make a binary divisor of 4 bits in VHDL. The process i'm using to get the quotient is to compare and substract. So, what I want to do is to subtract certain binary number wi...
13 years agoOf course. That algorithm is controlled by state machine so you need a clock.
What tricky says is correct. If you forget signals from sensivity list ( all the signals that are inputs to the process ), the code will be synthetized anyway. But the simulation show inferred latches, because the ommited signals. Why do you make a substraction with a component? If you define a vector as unsigned you can do simply: c <= a - b;
