13 years agoProblem! Binary Divisor: Error (10028): Can't resolve multiple constant drivers
Hi! I'm trying to make a binary divisor of 4 bits in VHDL. The process i'm using to get the quotient is to compare and substract. So, what I want to do is to subtract certain binary number wi...
13 years ago --- Quote Start --- May be this approach is similar like yours. a-You create a register, call it "resto" for example, with 2N bits. ( N = 4 in this case ). b-Fill the 4 MSb bits of that register with '0'. c-Fill the 4 LSb bits with the dividendo. d-Substract the "4 MSb bits of resto" - divisor. e-If the substraction is greater or equal than "0000" fill the 4 MSb of "resto" with the result of the substraction. If the result of substraction is negativo don't change "resto". f-Shift "resto" one position to the left. g-Repete the procedure from step 'd' until you entered all the bits of the original dividendo. I hope you understand me. --- Quote End --- Shouldn't that be controlled by a clock?
