--- Quote Start ---
I generated a inverted clock from a dedicated clock-pin.
The statement is: assign clk_62M_inv= ~clk_62M;//clk_62M is the input clock from the dedicated clock-pin
The clock period is 16ns.
I want to constrain the time distance from clk_62M's rising edge to clk_62M_inv's rising edge to be 7.5ns-8.5ns.
How to do this?
--- Quote End ---
The question is whether clk_62M_inv is a physical output pin or not. In the case of being an output pin you will need a PLL, as kaz indicates, and preferably put that pin on one of the PLL's dedicated output pins.
If clk_62M_inv is an internal clock, you don't have to do anything, Quartus II and TimeQuest will take care of that. TimeQuest regards the the inverted clock as a 'original' clock where you also act on the falling edge. You may have to add some additional set_output_delays constraints to cope with actions on that falling edge.
