14 years ago --- Quote Start --- Firstly, I just want to make the LCD work --- Quote End --- Reduce your complexity. Build an SOPC system with a JTAG-to-Avalon-MM master and a PIO component and an LCD component. Connect the PIO component to LEDs on your board. Then use SystemConsole to perform read/write access to your LEDs. When you can blink your LEDs, you know that you have SystemConsole working. Then perform read/write accesses to the LCD. The LCD needs to be initialized before you will see characters. Per this thread: http://www.alteraforum.com/forum/showthread.php?t=29042 Use the Optrex manual as a reference: http://www.optrex.com/pdfs/dmcman_full.pdf Cheers, Dave
