13 years agoproblem (?) using shared variables
Hi, I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
en...
13 years ago --- Quote Start --- you shouldnt use clk_en to generate a clock. Forget about generating a 2nd clock. Just use the clk_en directly. --- Quote End --- Hi, Based on your recommendation, I developed the following code:
library ieee;
use ieee.std_logic_1164.all;
entity clock_gen is
generic(N: integer := 10);
port(
mclk: in std_logic;
rst: in std_logic;
clk: out std_logic);
end clock_gen;
architecture arch of clock_gen is
signal cnt: integer := 0;
begin
process(mclk, rst)
begin
if(rst = '1') then
cnt <= 0;
clk <= '0';
elsif(rising_edge(mclk)) then
cnt <= cnt + 1;
if(cnt = N) then -- this will give you an enable rate of clk/N
clk <= '1';
else
clk <= '0';
end if;
end if;
end process;
end arch;
The simulation of this code produced the following result: https://www.alteraforum.com/forum/attachment.php?attachmentid=7549 A "return to zero" was needed. Also, I would prefer a 50% duty cycle clock generator. So I did some modifications on your recommendation and produced the following code:
library ieee;
entity clock_gen is
generic(N: integer := 20);
port(
mclk: in std_logic;
rst: in std_logic;
end clock_gen;
begin
process(mclk, rst)
begin
if(rst = '1') then
cnt <= 0;
clk <= '0';
cnt <= cnt + 1;
if(cnt >= (N - 1)/2) then -- this will give you an enable rate of clk/N
if(cnt = (N - 1)) then
clk <= '0';
cnt <= 0;
else
clk <= '1';
end if;
else
clk <= '0';
end if;
end if;
end process;
end arch;
Regards Jaraqui
