13 years agoproblem (?) using shared variables
Hi, I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
en...
13 years ago --- Quote Start --- Its not really an opinion, its a fact. Hence why its not working. --- Quote End --- Tricky, It seemed to be a simulation bug. Implementing the code, it worked well surprisingly. The only modifications needed were: converting input/output to std_logic and dividing the 50 MHz frequency oscillator to a 1 Hz (to be visually observable). Here it´s the modificated version:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity counter_with_sharedvar is
port (mclk: in std_logic;
rst: in std_logic;
digit1, digit2: out std_logic_vector(3 downto 0));
end entity;
architecture counter of counter_with_sharedvar is
shared variable temp1, temp2: integer range 0 to 9;
signal clk: std_logic;
begin
proc0: process(mclk, rst)
variable count: integer := 0;
begin
if(rst = '1') then
count := 0;
elsif(mclk'event and mclk='1') then
if(count < 25_000_000) then
clk <= '0';
count := count + 1;
elsif(count >= 25_000_000) then
if(count = 50_000_000) then
count := 0;
clk <= '0';
else
count := count + 1;
clk <= '1';
end if;
end if;
end if;
end process proc0;
proc1: process (clk, rst)
begin
if(rst = '1') then
temp1 := 0;
elsif (clk'EVENT and clk='1') then
if (temp1=9) then
temp1 := 0;
else
temp1 := temp1 + 1;
end if;
end if;
end process proc1;
proc2: process (clk, rst)
begin
if(rst = '1') then
temp2 := 0;
if (temp1=9) then
if (temp2=9) then
temp2 := 0;
else
temp2 := temp2 + 1;
end if;
end if;
end if;
end process proc2;
digit1 <= conv_std_logic_vector(temp1, 4);
digit2 <= conv_std_logic_vector(temp2, 4);
end architecture;
Best regards Jaraqui
