10 years agoProbem in a state machine code
Hi, I'm new in VHDL and I have a problem with this code: The problem is that when I program it on The FPGA, even when SW(4) is equal to 0, LEDR(0) is equal to 1. And It stays on this state even...
10 years ago --- Quote Start --- Have you assigned the correct pins to the ports? --- Quote End --- Yes, I absolutely did. The problem can't be in the syntax of clk_50 ? Shouldn't I write clock_50 rather than clk_50 ?
