10 years agoProbem in a state machine code
Hi, I'm new in VHDL and I have a problem with this code: The problem is that when I program it on The FPGA, even when SW(4) is equal to 0, LEDR(0) is equal to 1. And It stays on this state even...
10 years ago --- Quote Start --- Have you written a simulation testbench? Why have you used > to compare the switch values? --- Quote End --- No, I didn't write a simulation testbench. I've just tested this code on the FPGA. Actually, I didn't write the code. It is automatically generated by HDL coder based on a state machine in Matlab/Simulink. That's why > are used. But, I've tried ='1' to compare the switch values and it leads always to the same results : the code doesn't work. Please, any help ?
