10 years agoProbem in a state machine code
Hi, I'm new in VHDL and I have a problem with this code: The problem is that when I program it on The FPGA, even when SW(4) is equal to 0, LEDR(0) is equal to 1. And It stays on this state even...
10 years agoI didn't look at your code, but you should check your board documentation to see if the switches or LEDs are wired as active low rather than active high.
