Prime PRO Design Space Explorer II
I'm trying to run DSE on my local machine using and I get the following error message and doesn't appear todo anythings?? Any idea why
File "common.py", line 1078, in load_plugins
File "<frozen importlib._bootstrap_external>", line 399, in _check_name_wrapper
File "<frozen importlib._bootstrap_external>", line 823, in load_module
File "<frozen importlib._bootstrap_external>", line 682, in load_module
File "<frozen importlib._bootstrap>", line 265, in _load_module_shim
File "<frozen importlib._bootstrap>", line 684, in _load
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 674, in exec_module
File "<frozen importlib._bootstrap_external>", line 888, in get_code
File "<frozen importlib._bootstrap_external>", line 455, in _validate_bytecode_header
ImportError: bad magic number in 'optimize_high_utilization_exploration': b'\x9e\x0c\r\n'
Design Space Explorer finished
- SyafieqS
Hi Dave,
You may need to disable window firewall and try to re-launch DSE.
- SyafieqS
Hi Dave,
Any update at your end?
- Dave123
I have turned of the windows defender firewall, but still get the same error message. I have also tried DSE II on a machine running Linux and got the same message.
- SyafieqS
Hi Dave,
Alternative methods:
- Use newer/previous version of DSE from Quartus
- Reinstall DSE and Quartus and launch it again.
