Preferred Text Editor command details to run specific parameters for the editor
Open quartus ->Tools -> Options -> Preferred Text Editor "Text editor" select "Custom" "Command-line" and enter either of followings:
"%PATH_TO_VSCODE%\Microsoft VS Code\Code.exe" -r -g %l %f
"%PATH_TO_VSCODE%\Microsoft VS Code\Code.exe" %l %f %p
"%PATH_TO_VSCODE%\Microsoft VS Code\Code.exe" -r -g -n%l %f
"%PATH_TO_VSCODE%\Microsoft VS Code\Code.exe" -r -g -n%l %f %p
"%PATH_TO_VSCODE%\Microsoft VS Code\Code.exe" -n%l %f
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- guilbaudl4 years ago
None of the line you wrote works. It only opens the concerned file without opening the folder I would like...
And I don't want to open the project, but the top folder depending on the path where the project is located (the top folder is a folder of many different projects)
Do you know how I can run command line in this "command line" field?
Loan
